I was wondering if there would be a way to properly lunch directly into a new excalidraw drawing.
Right now I pull the commands through get avalailable commands and created another shortcut that runs obsidian/excalidraw command create a new drawing in a new window.
The issue I’m running into is that I define a template folder and so when the short cut runs it asks for the template but before I can choose it goes knack to AFO.
I’d like to create, select template and stay in the new obsidian drawing. Would that be possible ?
Thanks for the help!
Welcome to the forum, @tpoupart!
I’ll need a bit more information to answer that question. Are you on macOS or iOS? And as I’m not familiar w/ the Excalidraw plugin …
… could you provide a screenshot of the workflow, please? Make sure to expand the AFO actions it uses so the extra options are visible. By the way, the way you describe it, it sounds less like an Excalidraw/AFO issue and more like a timing problem.
