As always, if BarCuts is already running on your Mac, either wait for the automatic update to pop up on its own (which might take up to 24h), or open the app window, then select “Check for updates …” from the main menu.
Let me know if you come across any issues with the new version, please! ![]()
This is a bugfix release, so we’ll have to get excited about that, I’m afraid.
- Tagger: When Finder’s “Show all filename extensions” is enabled, the Tagger would end each application name with “.app”, and list running apps twice (one with and one without “.app”). Fixed.
- License tab:
- Widened the super-narrow license key input field on macOS 14.
- When looking at your already set license key, hitting
Escwill no longer clear the license. Sorry!
- Decreased amount of under-the-hood logging output.
