As always, if BarCuts is already running on your Mac, either wait for the automatic update to pop up on its own (which might take up to 24h), or open the app window, then select “Check for updates …” from the main menu.
Let me know if you come across any issues with the new version, please! ![]()
This is for the most part a bugfix release that builds upon BarCuts 2025.3.
- Under some circumstances, right after app launch, BarCuts would not return all tagged workflows for the current active app.
- The URL scheme will now properly wake the app, and return correct results when it does.
- After updating, the “What’s New” window is now correctly brought to the front.
- The app window will grow a bit when viewing the Settings tab to make it clear that there’s more to see.
