BarCuts (Beta) 2025.0.4
Download the public beta here!
Barring major catastrophes or bugs, this is likely the last beta version before release. Many thanks for helping me test drive this thing :folded_hands:t3:
  • Trial state is not checked during app launch anymore, only when a workflow is triggered from the menu. Meaning that after the trial period has finished, the app won’t ask you to get a license right away, only when you try to run a workflow.
  • Updated one of the screenshots in the HowTo tab to reflect the overhauled menu structure.
  • When opening the app window from the menu, it will show the tab you’ve selected before you closed the window earlier.
  • Tagger: A few system apps, like Finder, were missing in the app selection. No longer!
  • Tagger: Shortcuts would sometimes refuse to fetch the list of applications. This shouldn’t happen anymore.
Thanks for testing the beta, I appreciate it. If you have issues specific to this release, sound off below, otherwise feel free to start a new topic!
Also, I’ve made a quick 55s introduction video for BarCuts the other day:
