As always, if Browser Actions is already running on your Mac, either wait for the automatic update to pop up on its own (which might take up to 24h), or open the app window, then select “Check for updates …” from the main menu.
Let me know if you come across any issues with the new version, please! ![]()
Another bugfix release. I’ve made a number of changes under the hood to keep Browser Actions run smoothly but there are no new headliner features this time.
- License tab:
- Widened the super-narrow license key input field on macOS 14.
- When looking at your already set license key, hitting
Escwill no longer clear the license. Sorry!
- Decreased amount of under-the-hood logging output.
