Browser Actions 2025.2.0
As always, if Browser Actions is already running on your Mac, either wait for the automatic update to pop up on its own (which might take up to 24h), or open the app window, then select “Check for updates …” from the main menu.
Let me know if you come across any issues with the new version, please! :call_me_hand:t3:
This is a so-called “chore” release. Lots of updated code, almost none of it visible. Same amount of love and care as usual, tho!
New Features
Added optional diagnostics reporting for those times when you need technical support. After clicking the “Contact the author” links in the main window or menu, the app can create a privacy-respecting report for you; add it to your outgoing support mail to help me help you.
The report is a simple HTML page, meaning you can open the report file in your browser and read it yourself before sending. I tried to make it as transparent as possible.
  • The license check during Shortcuts workflow runs was not all what it could be, so it was rewritten. When it runs into issues during license validation, it’ll be more specific now. Thanks again to both David and Leif for reports and their patience!
  • Added optional newsletter form at the end of the onboarding process.
  • More bug fixes and optimizations, what can I say.
