I’d like them all to go into an INBOX folder, so I can process them in bulk /sets.
The Note to self’ function / shortcut works really well, but I’d like to be able to direct the notes.
Any thoughts?
thank you
Any thoughts?
thank you
Welcome to the forum, @Alexander_Davies! I assume you’re talking about modifying ▶️ How to email a "Note to Self" to your Obsidian vault, correct? If so, take a look at the last action, the Create Note block. Currently, it says “Create note [(Mail Subject)] …” — change that to “Create note [INBOX/(Mail Subject)] …”. You’ll have to place the cursor in front of the “Mail Subject” variable, which can be a bit fiddly but it can be done ![]()
HTH!
Great, that was fiddly as you said, but I persevered and it works. Many thanks
Presumably, I can add any file path instead of INBOX, EG FOLDER/SUBFOLDER/mail subject
And so could set up different actions to email notes to different folders …
Or could I set up the shortcut to ask for a file path input?
I’m new to shortcuts, but presumably I could have an ‘obsidian folder’ text variable that could be appended to the ‘Mail subject’
Correct.
You could, but that workflow is triggered by incoming mail so you might not be around in that particular moment when Shortcuts asks you for a path, in which case Shortcuts would wait for your input. I guess that a) you don’t want to enter that path manually every time and b) you have a tiny set of possible target folders, so I would …
