Need help with Path structure
Complete newbie here. Building a short cut that moves notes to a specific folder. Using the Move file action
I first build a text block: /01 proyectos/2 work/209 agata/2093 proyectos tecnicos
Next I use that text in the Move file action, but I get /01%20proyectos/2%20work/209%20agata/2093%20proyectos%20tecnicos
Sure missing a conversion, but I do not know which one…
You’re not missing anything, you discovered a problem in AFO! Welcome to the forum, @awaldraff, I’m just sorry the reason for you joining is a bug :wink:
I have a suspicion what’s causing this, I’ll take a look into that early next week. If I’m right, I’ll only have to fix AFO’s companion plugin, Actions URI.
I’ll keep you posted!
Note to self
ZCO-1245
Great. No worries! I solved it temporarily using Move/Rename note
I looked into it, and it’s an issue with the app itself, not the companion plugin.
A fix will roll out with the next version of AFO!
