Problems with the "note/append" routes help
Problems with the “note/append” routes help
I am trying to append below the line but it doesn’t work but it only opens obsidian
I would appreciate if you could solve this problem or give me some advice.
obsidian://actions-uri/note/append?vault=Cerebro%20Digital&periodic-note=daily&below-headline=karmaBueno%3A%3A&content=23%3A27hola
Welcome, @cristian_cortes! It’s a bit hard to say what the cause here from afar, so let’s start at the beginning:
Is Actions URI installed and enabled? I got several reports like this where the Obsidian had silently deactivated Actions URI for some reason (I suspect it happened during sync handshakes or something like that), and then the API calls just failed.
If that’s definitely not it, would you be willing to provide some log output? If so:
  • In your vault, please install my plugin Logstravaganza
  • Configure it to output NDJSON, log level “Debug”
  • Enable Logstravaganza
  • Disable Actions URI
  • Enable Actions URI again
  • Run the URL call you’re having issues with. Repeat it until you run into an issue, please.
  • Disable Logstravaganza
  • Send me the output (via private message or email)
