I am trying to do a shortcut, that prompts for a filename and creates a new obsidian file in my inbox, using the Templater plugin.
Everything works great, but the templater plugin doesn’t run the cursor insertion part from the
<% tp.file.cursor(0) %>
I have enabled cursor insertion in the Templater plugin. And it works when I manually invoke the template from within Obsidian.
But when I use the “create note” with templater, it just lets the file.cursor tag be, and the cursor appears at the top of the note.
This is of course a minor annoyance. But have anybody got a good solution for this?
