I tried creating a new note from a template (core plugin), but the properties are missing in the new note. What did I do wrong?
Regards,
Alex
Regards,
Alex
Hi @DeLub, welcome to the forum!
What exactly do you mean when you say “the properties are missing in the new note” — do you mean in the note in Obsidian, or in the note object returned by the action in Shortcuts?
Hi, Thnx and thnx for your work btw
I meant the new note in obsididan. My template only consists of a yaml header and nothing else. But this results in a completely empty note in Obsidian.
I’m afraid I can’t reproduce this issue, see video:
Do you do anything different? If not, it’d be helpful if you could show me the template in question and maybe a screenshot of the action you’re trying to set up. Also: Which version of AFO, Obsidian, macOS/iOS are you using?
sorry for the late reply…
Hmm… now it works. I probably did something wrong. Typo in the template name perhaps?
Anyway, sorry to have bothered you, and thanks.
All good, no worries. We’ve all been there, I certainly have been …several times ![]()
