What This Workflow Does
It’s a quick task entry workflow that lets you tag the new task with one or more tags from your vault. The task is then inserted next to a placeholder in your daily note.
The result will:
- Prompt you for a short text
- Fetch the list of tags from your vault
- Let you select one or more of them
- Insert both as a new task at a placeholder in your current daily note
Please note: The workflow assumes there’s a current daily note.
Download
Download Quick tasks entry with tags picker.shortcut workflow. Double-click the downloaded file to install the workflow in Apple Shortcuts.
Requirements
- Actions for Obsidian
- Obsidian
Workflow Video
Workflow Screenshot
Workflow history / Change log
2024-02-29
Adjusted vault handling to work with AFO 2024.1.
2023-03-21
First version.
