Actions URI 1.5.0 was released today.
- Check the GitHub release page: Release 1.5.0 · czottmann/obsidian-actions-uri · GitHub
- New route path:
/filefor working with files. The Obsidian API doesn’t allow for uploading attachment files, but now you can at least handle them. (#85)/file/list: Returns the paths of all files in the vault./file/get-active: Return the path of the currently active/ focussed file./file/open: Opens a file in Obsidian./file/delete: Deletes a file./file/trash: Moves a file to the trash./file/rename: Renames a file.
- New route:
/note/get-activereturns the currently active/ focussed note. - New route:
/note/get-first-namedreturns the first note found with a given name. - New route:
/note/touchsets the modification date of a note to the current date and time (side effect: it makes Obsidian reload it in views/ embeddings).
- Appending below headline: Now inserts before any trailing new lines in a section instead of after them.
- Changed route:
/command/executeno longer requires thex-successandx-errorparameters to be present. If they are, they will be used, but they are optional now. (#84) - Removed route:
/vault/list-folderswas marked as deprecated in 0.16, and is now gone for good. Use/folder/listinstead.
