Actions URI 1.6.0 was released today.
- Check the GitHub release page: Release 1.6.0 · czottmann/obsidian-actions-uri · GitHub
- All
/noteroutes gained support for working with periodic notes (daily, weekly, etc.). - All
/noteroutes gained support for UID-based note references. Notes can now be referenced by their UID instead of their file path, so if you’re storing a UID in your front matter, give it a go. Make sure to check that the correct frontmatter key is configured in the … - New settings UI. The plugin now has a settings page in Obsidian’s settings.
/note/get-active-notereturns the current selection as part of its result. (Plain-text only for now.) Thanks to @FelipeRearden for the suggestion! [#90]/note-propertiesnow supports working with current periodic notes (daily, weekly, etc.)- When using
/note/appendor/note/prependto insert text below a headline, the route no longer joyfully reports success even when the headline couldn’t be found. Instead, the routes now support a conditionalif-headline-missingparameter to specify what to do in that case: report an error (the new default), skip the operation (the old default behavior), or add the headline to the end of the note. Thanks to @vitaly-rudenko for the bug report! [#91]
Deprecation notice
All dedicated periodic note-related routes (/daily-note/*, /weekly-note/*, /monthly-note/*, /quarterly-note/*, /yearly-note/*) are officially deprecated, and will be removed in early 2025. Please update your scripts accordingly.
There will be no further work on these routes going forward.
- Fixes search/replace in notes, which wouldn’t work if the search term was a string but contained regex-like characters (
$,^, etc.) [ZCO-606] /note-properties/getwon’t automatically open the note anymore.- Fixes template path handling in
/note/create, which was very strict, and didn’t allow for specifying a template file outside the configured template folder.
