Mononote 1.1.1 was released today.
- Check the GitHub release page: Release 1.1.1 · czottmann/obsidian-mononote · GitHub
IMPORTANT: For Mononote to work correctly, Settings → Editor → Always focus new tabs MUST BE ENABLED. This is because it hooks into the active-leaf-change event which is not fired for new files when this setting is disabled. Technical limitations, sorry.
New
- Tab handling has been entirely reworked to be more robust and reliable.
- The plugin now respects pane & window boundaries as it should, superfluous tabs will only be closed in the active pane or window.
- If Mononote encounters a duplicate, it’ll now favor the existing tab, and close the new one. This prevents losing undo history.
- Adds workaround for files which don’t trigger Obsidian’s
file-openevent, meaning Mononote will now work with files which aren’t notes, such as PDFs or images. See the README for information on the updated behavior, and what to expect. [#2] - Adds support for anchor links: If note A is already open in a tab 1, and you attempt to open note A in a tab 2, but with an anchor link (reference to a headline or block), tab 2 will be closed, while tab 1 will focus the anchor link. [#3]
