Sync_Contacts_with_Notes asking for URL
Hi all, I am currently trying out the Sync_Contacts_with_Notes shortcut. I am very new to Apple Shortcuts, please bear with me if this is a noob question.
When I run the Shortcut, I gets back to me with the following message (in German): Which UIRL would you like to add? (see attached screenshot). I am at a loss as to what to do next.
Thanks in advance for any help you can provide,
Alex
Hi @hup, welcome to the forum. Ah yes, that demo workflow was made for an older version of AFO and hasn’t been adjusted yet. When you run it in Shortcuts, with it open in the editor, which of the actions is popping up that dialog? The active one should be subtly highlighted.
Hello Carlo, thanks for pointing me in the right direction. The action that causes the dialog box to pop up is this one:
Ah, I see. I fixed the workflow and updated it, please re-download: Sync Contacts with Notes
Hope this helps!
Wow, thanks Carlo!The updated version does exactly what I wanted :blush:
I appreciate your help very much.
