Is there a way to transfer the settings and history from Beta to product version? How do I get a license? Thanks.
Doug Warren
Settings: no, sorry. History: yes.
The history is stored in a local SQLite database. Copying ~/Library/Group\ Containers/group.co.zottmann.ListeningPost-beta/tracks.* to ~/Library/Group\ Containers/group.co.zottmann.ListeningPost/ should do the trick. (This will overwrite your non-beta history, of course.)
If you want to do that the history, I recommend this order:
- Set up the channels in the non-beta app.
- Quit LP.
- Copy the
tracks.*files. - Launch LP, go to the history, check your history is there.
The info which track was scrobbled to which channel should be retained, so there should not be another scrobbling attempt for existing tracks. Let me know how it works!
You can either go through the License tab of the app, or you visit https://actions.work/store ![]()
Hope this helps!
PS: I’ve moved your question to a new topic because it’s a good question!
That worked, and now I see my history from the Beta usage.
Thanks, Doug
