What am I doing wrong? This is driving me nuts
What is going on here? This shortcut was working but now hangs in the AfO action. I can’t make sense of it. Shortcut is here it requires Data Jar and Logger for Shortcuts apps. Since you haven’t even seen this before, you will need an initialization helper from here
iOS 16.6.1
iPhone 13 Pro
Actions for Obsidian 1.2.0(3811)
Obsidian debug info:
SYSTEM INFO:
Operating system: ios 16.6.1 (Apple iPhone)
Obsidian version: 1.4.8 (107)
API version: v1.3.7
Login status: logged in
Catalyst license: vip
Live preview: on
Legacy editor: off
Base theme: dark
Community theme: Minimal v7.1.2
Snippets enabled: 0
Restricted mode: off
Plugins installed: 25
Plugins enabled: 18
1: Advanced Tables v0.19.1
2: Advanced URI v1.38.1
3: Dataview v0.5.56
4: Tag Wrangler v0.5.12
5: Periodic Notes v0.0.17
6: QuickAdd v1.2.1
7: Actions URI v1.3.0
8: Callout Manager v1.0.1
9: Better Word Count v0.10.0
10: Natural Language Dates v0.6.1
11: Calendar v1.5.10
12: Homepage v3.5.2
13: Outliner v4.8.0
14: Shortcut Launcher v1.0.1
15: Checklist v2.2.12
16: Templater v1.16.0
17: Omnisearch v1.17.0
18: Text Extractor v0.4.6
RECOMMENDATIONS:
Custom theme and snippets: for cosmetic issues, please first try updating your theme and disabling your snippets. If still not fixed, please try to make the issue happen in the Sandbox Vault or disable community theme and snippets.
Community plugins: for bugs, please first try updating all your plugins to latest. If still not fixed, please try to make the issue happen in the Sandbox Vault or disable community plugins.
I have attached a screen shot of the logged info. I could also run the Logstravaganza plugin and post that log note here if that helps.
Good morning, this sounds like the companion plugin Actions URI is inactive. But apparently it isn’t, huh.
Logstravaganza output would help indeed! Please install, enable, restart Obsidian (or “Reload app without saving”) so that it hopefully picks up the Actions URI init phase. Run your workflow, and should you encounter a stalling, post the Logstravaganza note as a reply or send to me as a private note, and I’ll take a look!
Here is the note from the phone:
Summary
Timestamp Originator Level Message
2023-09-11T15:32:46.213Z plugin:logstravaganza info [Logstravaganza] Proxy set up (v1.2.0)
2023-09-11T15:33:04.819Z plugin:table-editor-obsidian:28187:21 debug getCursorPosition was called: line 7, ch 0
2023-09-11T15:33:04.819Z plugin:table-editor-obsidian:28203:21 debug acceptsTableEdit was called on row 7
2023-09-11T15:33:04.819Z plugin:table-editor-obsidian:28231:21 debug getLine was called on line 7
2023-09-11T15:33:04.820Z plugin:table-editor-obsidian:28231:21 debug getLine was called on line 7
2023-09-11T15:33:04.820Z plugin:table-editor-obsidian:28187:21 debug getCursorPosition was called: line 7, ch 0
2023-09-11T15:33:04.820Z plugin:table-editor-obsidian:28203:21 debug acceptsTableEdit was called on row 7
2023-09-11T15:33:04.821Z plugin:table-editor-obsidian:28187:21 debug getCursorPosition was called: line 7, ch 0
2023-09-11T15:33:04.821Z plugin:table-editor-obsidian:28203:21 debug acceptsTableEdit was called on row 7
2023-09-11T15:33:04.821Z plugin:table-editor-obsidian:28231:21 debug getLine was called on line 7
2023-09-11T15:33:04.822Z plugin:table-editor-obsidian:28187:21 debug getCursorPosition was called: line 7, ch 0
2023-09-11T15:33:04.822Z plugin:table-editor-obsidian:28203:21 debug acceptsTableEdit was called on row 7
2023-09-11T15:33:04.822Z plugin:table-editor-obsidian:28231:21 debug getLine was called on line 7
2023-09-11T15:33:04.823Z plugin:table-editor-obsidian:28203:21 debug acceptsTableEdit was called on row 7
2023-09-11T15:33:04.823Z plugin:table-editor-obsidian:28231:21 debug getLine was called on line 7
2023-09-11T15:33:04.823Z plugin:table-editor-obsidian:28187:21 debug getCursorPosition was called: line 7, ch 0
2023-09-11T15:33:10.388Z plugin:logstravaganza info [Logstravaganza] Proxy set up (v1.2.0)
2023-09-11T15:33:10.520Z app.js:1:2127018 log {}
2023-09-11T15:33:10.531Z plugin:calendar:3828:13 debug [Calendar] Trying to switch Moment.js global locale to en-us, got en
2023-09-11T15:33:10.585Z plugin:actions-uri:12295:11 log [Actions URI] Registered URI handlers: [“actions-uri”,“actions-uri/command”,“actions-uri/command/list”,“actions-uri/command/execute”,“actions-uri/dataview”,“actions-uri/dataview/table-query”,“actions-uri/dataview/list-query”,“actions-uri/folder”,“actions-uri/folder/list”,“actions-uri/folder/create”,“actions-uri/folder/rename”,“actions-uri/folder/delete”,“actions-uri/folder/trash”,“actions-uri/info”,“actions-uri/note”,“actions-uri/note/list”,“actions-uri/note/get”,“actions-uri/note/open”,“actions-uri/note/create”,“actions-uri/note/append”,“actions-uri/note/prepend”,“actions-uri/note/delete”,“actions-uri/note/trash”,“actions-uri/note/rename”,“actions-uri/note/search-string-and-replace”,“actions-uri/note/search-regex-and-replace”,“actions-uri/omnisearch”,“actions-uri/omnisearch/all-notes”,“actions-uri/omnisearch/open”,“actions-uri/daily-note”,“actions-uri/daily-note/list”,“actions-uri/daily-note/get-current”,“actions-uri/daily-note/get-most-recent”,“actions-uri/daily-note/open-current”,“actions-uri/daily-note/open-most-recent”,“actions-uri/daily-note/create”,“actions-uri/daily-note/append”,“actions-uri/daily-note/prepend”,“actions-uri/daily-note/search-string-and-replace”,“actions-uri/daily-note/search-regex-and-replace”,“actions-uri/weekly-note”,“actions-uri/weekly-note/list”,“actions-uri/weekly-note/get-current”,“actions-uri/weekly-note/get-most-recent”,“actions-uri/weekly-note/open-current”,“actions-uri/weekly-note/open-most-recent”,“actions-uri/weekly-note/create”,“actions-uri/weekly-note/append”,“actions-uri/weekly-note/prepend”,“actions-uri/weekly-note/search-string-and-replace”,“actions-uri/weekly-note/search-regex-and-replace”,“actions-uri/monthly-note”,“actions-uri/monthly-note/list”,“actions-uri/monthly-note/get-current”,“actions-uri/monthly-note/get-most-recent”,“actions-uri/monthly-note/open-current”,“actions-uri/monthly-note/open-most-recent”,“actions-uri/monthly-note/create”,“actions-uri/monthly-note/append”,“actions-uri/monthly-note/prepend”,“actions-uri/monthly-note/search-string-and-replace”,“actions-uri/monthly-note/search-regex-and-replace”,“actions-uri/quarterly-note”,“actions-uri/quarterly-note/list”,“actions-uri/quarterly-note/get-current”,“actions-uri/quarterly-note/get-most-recent”,“actions-uri/quarterly-note/open-current”,“actions-uri/quarterly-note/open-most-recent”,“actions-uri/quarterly-note/create”,“actions-uri/quarterly-note/append”,“actions-uri/quarterly-note/prepend”,“actions-uri/quarterly-note/search-string-and-replace”,“actions-uri/quarterly-note/search-regex-and-replace”,“actions-uri/yearly-note”,“actions-uri/yearly-note/list”,“actions-uri/yearly-note/get-current”,“actions-uri/yearly-note/get-most-recent”,“actions-uri/yearly-note/open-current”,“actions-uri/yearly-note/open-most-recent”,“actions-uri/yearly-note/create”,“actions-uri/yearly-note/append”,“actions-uri/yearly-note/prepend”,“actions-uri/yearly-note/search-string-and-replace”,“actions-uri/yearly-note/search-regex-and-replace”,“actions-uri/search”,“actions-uri/search/all-notes”,“actions-uri/search/open”,“actions-uri/tags”,“actions-uri/tags/list”,“actions-uri/vault”,“actions-uri/vault/open”,“actions-uri/vault/close”,“actions-uri/vault/info”,“actions-uri/vault/list-folders”,“actions-uri/vault/list-all-files”,“actions-uri/vault/list-non-notes-files”]
2023-09-11T15:33:10.587Z plugin:omnisearch:49:6965 time Omnisearch - Indexing total time
2023-09-11T15:33:10.588Z plugin:omnisearch:49:7087 log Omnisearch - 286 files total
2023-09-11T15:33:10.588Z plugin:omnisearch:49:7139 log Omnisearch - Cache is enabled
2023-09-11T15:33:10.588Z plugin:omnisearch:49:7212 time Omnisearch - Loading index from cache
2023-09-11T15:33:10.620Z plugin:callout-manager:1620:15 warn Unable to fetch Obsidian stylesheet. {}
2023-09-11T15:33:10.840Z plugin:dataview:12575:17 log Dataview: all 286 files have been indexed in 0.258s (286 cached, 0 skipped).
2023-09-11T15:33:10.976Z plugin:omnisearch:49:7312 timeEnd Omnisearch - Loading index from cache
2023-09-11T15:33:10.976Z plugin:omnisearch:49:7456 log Omnisearch - Total number of files to add/update: 5
2023-09-11T15:33:10.976Z plugin:omnisearch:49:7556 log Omnisearch - Total number of files to remove: 1
2023-09-11T15:33:11.240Z plugin:dataview:12579:21 log Dataview: Dropped cache entries for 1 deleted files.
2023-09-11T15:33:11.262Z plugin:omnisearch:39:2405 log Omnisearch - Search cache written
2023-09-11T15:33:11.263Z plugin:omnisearch:49:8074 timeEnd Omnisearch - Indexing total time
Thanks. Nothing out of the ordinary, though. I see that Actions URI was initialized correctly (“Registered URI handlers”) but what I don’t see is an incoming AFO call. I’ll assume your vault name (“Creeds-PKM”) is correctly set in the workflow?
Yes, it is correct. I’m getting slightly different errors on the Mac.
here is the note from the Mac:
Summary
I stripped out the logging and setup the Obsidian Sandbox with the Actions URI and Logstravaganza plugins. Setup Daily Note and Templates core plugins and ran the shortcut against that. Same issue of the “runner quit unexpectedly.”
Logstravaganza note:
2023-09-11T16:19:39.779Z plugin:logstravaganza info [Logstravaganza] Proxy set up (v1.2.0)
SYSTEM INFO:
Obsidian version: v1.4.9
Installer version: v1.3.7
Operating system: Darwin Kernel Version 22.6.0: Wed Jul 5 22:21:56 PDT 2023; root:xnu-8796.141.3~6/RELEASE_X86_64 22.6.0
Insider build toggle: on
Live preview: on
Legacy editor: off
Base theme: dark
Community theme: none
Snippets enabled: 0
Plugins enabled: 2
1: Actions URI v1.3.0
2: Logstravaganza v1.2.0
RECOMMENDATIONS:
Hmm. “The runner quit unexpectedly” leads me to believe AFO has crashed, or there might be a zombie process hanging around. Usually, I see those errors when Shortcuts has gone awry (as opposed to Obsidian & its plugins).
Could you check macOS’ Activity Monitor, please?
I don’t see anything out of the ordinary. The full CPU or Memory activity lists are too long to post here and a .md or .txt seem to be disallowed files for the forum uploader. CPU and Memory activity seem perfectly normal.
Thanks for the heads-up, I’ve added the extensions to the whitelist!
So, to re-iterate, I think the hangs are definitely a Shortcuts/AFO issue. If you have the time, try a reboot and see whether it changes anything. Shortcuts sometimes does weird things without showing anything in the Activity Monitor (which is always fun).
Are you running Ventura or Sonoma?
UPDATE: Sorry, it’s been ~30°C over here all day and I have a hard time thinking straight. I just realized you’re saying the problem only occurs with one workflow but on both platforms. Apologies for being a bit dense. :grimacing: I’ll check your workflow in the morning.
:laughing: I understand.
It’s curious to me that it times out on iOS but the “runner quit unexpectedly” on Mac OS. Probably just differences in how the systems are woven together.
The Mac is on Ventura 13.5.2 (22G91)
I restarted the system and ran against the Obsidian Sandbox with no change in the result. I also restarted the iPhone and iPad and tried again. No change.
Have a cold beverage and a good evening. :cup_with_straw:
Good morning, I’ve found out why the runner error occurs in terms of input: Both your Vault and Log Heading are empty — I noticed some log messages were missing, and had to turn on the “Log Error If Message Empty” option in the Logger actions to get a confirmation.
(Disclaimer: I worked with the two Shortcuts you’ve provided.)
If I read the “Initialize Obsidian Environment” workflow right, you set the keys vaultKey and logKey in the ENV dict. But in the main workflow, you try to access vaultName and logHeading, and neither contains anything.
That said: the AFO action shouldn’t just explode, it should gracefully handle the input and show an error. I’ll get right to that.
I hope my responses today are more helpful than yesterday’s :sweat_smile:
@Creed BTW, I’ve changed the dictionary keys in my Data Jar to reflect your ENV dict, and to keep the workflow from drawing blanks, and then it worked fine. I’m not certain why the runner would crash.
Of course, the dict might contain invisibles that Logger may not show, like zero-length whitespace etc. — I guess you’ve tried setting dayLogMarker and vaultName explicitly to rule out “faulty” data in your ENV dict in Data Jar?
Yeah, I did discover that I had some naming issues. This resulted from a change in thinking not being followed all the way through. Thank you for looking this over and pointing out the issue. I feel a bit like a dolt.
Happens. One of the biggest boons (for me) in working with IDEs are all the different “What are you talking about” mechanisms checking my variable names and whatnot :joy:
But hey, you got it sorted out now, right?
