Beta 2026.0.3 (Beta 3)
New beta build is out, grab it from the Listening Post product page!
Mastodon / ActivityPub support — You can now post recognized tracks to the fediverse! Connect your Mastodon (or compatible) account, customize your post template, and choose between automatic posting or manual posts via the track context menu.
  • Notification click action: Configure what happens when you click a track notification — open in Apple Music, Last.fm, ListenBrainz, Deezer, or run a Shortcuts workflow. Find it in Settings, below the notification toggle.
  • Fixed an issue where the Channels tab caused the main window to grow endlessly tall on macOS 15.6+. Window sizing is now properly constrained across macOS versions.
Under the hood
So. Many. Things. :sweat_smile:
